17255 Discussions
How would you create infinite simulation loop in modelsim using erilog/ vhdl
Any ideas, hints would be helpful.
You could just post your homework assignment for us. :)
You could create a task that contains your loop. Then just schedule the task to run at some predefined interval.
Jake
Hi Jakob,
I wish this was only an assignment :)
I do thank you though and if you do have any other suggestions please do let me know.
thanks
I presume you are aware of the $stop and $finish directives in verilog?
Descriptions from the sutherland HDL reference:
$finish;
Finishes a simulation and exits the simulation process.
$stop;
Halts a simulation and enters an interactive debug mode.
Jake
thanks for your help..
This should make modelsim get stuck in an infinite loop in VHDL:
signal a : std_logic := '1'; signal b : std_logic := '0'; ... b <= a and not b;
thanks tricky... did end up doing something like that. general question can anyone give me an example how do i make 2 always loops to be continuously switching between each other
you can try
process
begin
loop
wait until clk='1';
end loop;
end process;
Did I conceive a circuit under quartusII and do I want validated it by a file of data to elaborate by a program in C language, and to recover the exits as a file text, how to make?
