16019 Discussions
I am using quartus pro 18.1 I get a error unconstrained ports can only be associated in whole if I cast a unconstrained std_logic_vector to an unsigned for my generic memory
bswag
I have memory block
I have memory as follows:
entity memory is
port
clk : in std_logic;
din : std_logic_vector;
wr : in std_logic;
dout: std_logic_vector
When I instantiate for example
din_unsigned : unsigned(7 downto 0)
dout_unsigned : unsigned(7 downto 0);
begin
my_memory : entity work.memory is
  port map
clk => clk,
din => std_logic_vector(din_unsigned),
wr => wr,
unsigned(dout) => dout_unsigned
I don't think this is ambiguous, however the casting of the unstrained output causes an error 13726 unconstrained ports can only be associated in whole.
The workaround is using a dummy std_logic_ vector signal and a subsequent casting to unsigned.
Please fix this or enlighten me to the rationale for this rule.
IDeyn
New Contributor III
Hi bswag.
There is a perfect reference about VHDL type casting - http://www.synthworks.com/papers/vhdl_math_tricks_mapld_2003.pdf
Hope it helps.
Ivan
GuaBin_N_Intel
Try to build similar coding and able to compile successfully in Pro 18.1. Did not have the error message.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cast_test is
  port
clk,wren : in std_logic;
address : in std_logic_vector (7 downto 0);
    input : in unsigned(7 downto 0);
    output,q_out : out unsigned(7 downto 0)
end entity cast_test;
architecture rtl of cast_test is
component RAM1P_w8
port (
data  : in std_logic_vector(7 downto 0) := (others => '0'); -- ram_input.datain
address : in std_logic_vector(7 downto 0) := (others => '0'); --      .address
wren  : in std_logic          := '0';       --      .wren
clock  : in std_logic          := '0';       --      .clk
q    : out std_logic_vector(7 downto 0)           -- ram_output.dataout
end component;
component test
  port
    input : in std_logic_vector(7 downto 0);
    output : out std_logic_vector(7 downto 0)
end component;
signal w_input : unsigned (7 downto 0);
begin
w_input <= input;
 test_inst : test
  port map (
   input => std_logic_vector(w_input),
   unsigned(output) => output
RAM1P_w8_inst : RAM1P_w8
port map(
data  => std_logic_vector(w_input),
address => address,
wren  => wren,
clock => clk,
unsigned(q)  => q_out
end architecture rtl;
********************* Sub module ***************************
library ieee;
entity test is
  port
end entity test;
architecture rtl of test is
begin
 output <= not input;
bswag
Not quite similar my memory is unconstrained yours is constrained to length 8.
GuaBin_N_Intel
It is not allowed to constrain it with different bit width and have to include the port as a whole from what I understand https://www.intel.com/content/www/us/en/programmable/quartushelp/18.0/index.htm#msgs/msgs/evrfx2_vhdl_unconstraint_formal_partial_assignment.htm
