17128 Discussions
I can't install USB Blaster driver on Windows 10
BRIANNN
I have some troubles when I try to install the driver for USB Blaster (the first generation, not Blaster II). I'm using the 10 and Quartus lite 20.1 software. I also find the solution on this page. Why does the Intel® FPGA Download Cables drivers installation fail on Windows* operating system? But when I install the Patch 0.02i and Patch 0.02stdp under the Quartus install location. It cannot find the Quartus pro software and Quartus Prime Standard Edition Programmer and Tools. I'm not sure I did the correct steps.
I have check the certification of the drivers, it has expired. Is there any newest version of the drivers?
Regards.
YuanLi_S_Intel
Sorry, i am confused. Do you mean you cant find the quartus path as per steps 8?
8. Enter the following path for the driver and enable include subfolders
- <Intel Quartus Prime software install directory>\quartus\drivers or
- <Intel Quartus Prime Programmer install directory>\qprogrammer\drivers or
- <Intel Quartus Prime Programmer install directory>\qprogrammer\quartus\drivers
YuanLi_S_Intel
BRIANNN
I mean, I cannot install the Patch 0.02i and Patch 0.02stdp in the Quartus lite.
regards.
BRIANNN
I have solve it. thanks.
sofi
Dear BRIANNN,
I've had the same issue and been trying for hours to install the patch. I already tried the solution posted by YuanLi, but can't seem to find the correct path. Could you please post the solution that worked for you?
Regards.
BRIANNN
I follow the steps in Why does the Intel® FPGA Download Cables drivers installation... . It's very important to choose the correct install path.
The path you need to choose when install the patch is a folder called Quartus, Which is the root directory of the whole Quartus software.
Hope this can help you.
Regards.
Araa
I have the same problem. Despite downloading the 0.02i patch in the quartus folder I always the receive the same error that the tools are not in the folder.
Can you help me?
