17268 Discussions
I can't program FPGA with linux command line mode
Rainwang
New Contributor II
i installed ubuntu 18.04+virtualbox on my windows 10 laptop, and then installed Quartus prime pro 20.1 linux version.
with above environment, I can download the FPGA successfully via the quartus programmer tools. but when i tried below instruction in linux command line mode,
quartus_pgm -c 1 -m jtag -o "p;$SOCEDS_DEST_ROOT/examples/hardware/a10_soc_devkit_ghrd/output_files/ghrd_10as066n2.sof"
it failed and error information is as below:
Error (20910): The host CPU is not supported in this version of the Intel Quartus Prime software. Intel requires that you upgrade to a more recent processor that supports SSE 4.2 and the POPCNT instruction
so, with the same configuration and the same target board, why i can't use the command line mode?
please help me to solve it. thanks in advance.
Rainwang
New Contributor II
after my test, to avoid above error, beow red highlighted items in windows features shall be unchecked.
after unchecking the items, the quartus_pgm can download the sof to FPGA without error.
Rainwang
New Contributor II
i tried again the next day, and the programming was successful. i believe i have not changed any configuration, i don't know why so.
Rainwang
New Contributor II
NurAiman_M_Intel
Thank you for sharing with us your findings and solution. I am glad that now you are able to move forward with your design.
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aiman
