Hi guys,
I have a problem with a project with Quartus and is this about two numbers that they are comparing when i go to the DE10-lite when all the switches are down the display throws number 7 and i want to have a 0 . i was looking to fix it but i don't find the problem . So Someone can help me please??
I uploaded my project if you want to look it
I found out that if KEY[1] and KEY[0] having the same clock pulse (80ns) means being pressed and released together, HEX0 will only show 0 (1000000) but not show 7 (1111000) check image.
If KEY[1] and KEY[0] having different clock pulse (80ns and 120ns), HEX0 will show both 0 (1000000) and 7 (1111000) check image.
Sheng
Do you have any further update or concern?
