16606 Discussions
I need help with simulation by ModelSim
Hello
As written in title, I am trying to do RTL simulation using ModelSim and stuck with it.
I'm a newbie to ModelSim and this question may seem stupid, but please help me (I looked for a lot of "How To"s but could not solve by myself).
Below is the code below I am trying to simulate. It is just dividing the frequency.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity FREQ_DIVIDER is port( CLK : in std_logic; decountCLK : out std_logic ); end entity FREQ_DIVIDER; architecture BEHAVIOR of FREQ_DIVIDER is -- Difining component(s) -- Difining signal(s) signal Q : std_logic_vector(25 downto 0); -- Difining procedure(s) begin decountCLK <= Q(25); process(CLK) begin if CLK'event and CLK = '1' then if Q = 49999999 then Q <= (others => '0'); else Q <= Q + 1; end if; end if; end process; end architecture BEHAVIOR;
This code works fine I think (since I used this and other codes to blink LEDs and confirmed it worked as I imagined).
And below is the test bench code for the above circuit.
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity FREQ_DIVIDER_TB is end entity FREQ_DIVIDER_TB; architecture BEHAVIOR of FREQ_DIVIDER_TB is -- Difining components component FREQ_DIVIDER port( CLK : in std_logic := '0'; decountCLK : out std_logic ); end component FREQ_DIVIDER; -- Difining signals signal CLK : std_logic; signal decountCLK : std_logic; constant CLK_period : time := 20 ns; begin uut : FREQ_DIVIDER port map( CLK => CLK, decountCLK => decountCLK ); CLK_process : process begin CLK <= '0'; wait for CLK_period/2; CLK <= '1'; wait for CLK_period/2; end process; end architecture BEHAVIOR;
- compiled both of the file above on ModelSim,
- did "Start Simulation", and
- did "Run all."
However when I see the waveform I get output signal (which is decountCLK) is always 'X'.
CLK is working fine.
Does anyone know how to solve this problem??
Any helps are appreciated.
The simulator does not know what you want for the initial value for Q. Supply an initial value for the signal, eg.,
-- Difining signal(s) signal Q : std_logic_vector(25 downto 0) := (others => '0');
and it will work fine.
An alternative method is to add a reset input and then add reset logic to the counter process.
Cheers,
Dave
Dear Dave
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
I did the way you told me and it worked fine!!
Thank you very much and I'm soooo happy now because this had been bothering me like 12 hours...
You're welcome.
Cheers,
Dave
