16214 Discussions
I trying to generate seriallite_iii_a10 example design. When I use Quartus Prime Pro the design is generated. When I use Quartus Prime Standard the IP Parameter Editor stops responding and I am forced to kill Quartus.
RMees
Only the ed_sim directory with sub-dirs aldec, cadence, mentor, synopsys and tb_components are created with a total of 24 files.
I cant use Pro because I use IP that is NOT compatible with Pro.
Using :
Quartus Prime Version 17.0.2 Build 602 07/19/2017 SJ Standard Edition.
Quartus Prime Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition.
AndyN
Are you trying to use the same project file or do you have two separate copies for each tool version?
RMees
No common files/directories between the two builds.
The standard build was failing for days before I even tried using pro.
