how and where in the Quartus II software can I config the programmable current drive strength for the output pins of an cyclon 2? thxLink Copied
Assignments > Pin Planner. you may need to open All Pins list in the View menu. also you may need to customize the columns to see drive strengths by right clicking and choosing Customize Columns.
it works!
thank you- Mark as New
What's the version requirement for Quartus II?
I can't config the programmable current drive strength in version 10.0. Thanks- Mark as New
--- Quote Start --- it works! thank you --- Quote End --- Could you tell me the version of Quartus II? Thanks
