17249 Discussions
IP Component files generated in wrong directory
VCham
I used the Altera PLL IP to generate a PLL for my project but it was generated in the wrong directory. I tried moving the files but Quartus II was then unable to find the IP Component. Is there a proper way to move these generated files within my project folders?
VCham
I figured out my issue.
What I meant by "wrong" was that it wasn't generated in the desired folder given our folder structure convention, and simply moving the files didn't update the pointers. I figured out that updating the paths found in the .qsf file solves the issue.
AndyN
What do you mean by the "wrong" folder? Where is it generating with reference to the .ip file?
VCham
