Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
IP Verification Variable Classes
I'm working to simulate some qsys designs with BFMs. While looking over the latest IP verification documentation I noticed an assortment of datatypes as either arguments or returns that I haven't see before, and can't seem to find any documentation on.
For instance, "get_response_read_id()" returns "AvalonTransactionId_t". Where are these guys defined so I can figure out how to declare, edit, and use them? Note: I'm guessing its all from the avalon_mm_pkg but that seems to be full of compiled nonsense.
Lucigen
Other Examples:
AvalonReadResponse_t
Request_t
Highlighted
The source to the BFM's is located In your Quartus directory, underneath ip/altera/sopc_builder_ip/verification subdirectory.
Where they are typedef'd depends on what BFM you are using.
Highlighted
Thanks Ted! I'm glad they decided to bury it in the installation folder instead of documenting it anywhere! Sarcasm aside, seriously, thanks! :)
