16689 Discussions
In-system memory content editor - No instances found!!
Rahul92
Hi All,
I am using Quartus prime pro 20.2 version to debug my ROM content. I don't see any ROM instances in my design. I have done the following so far:
1. Create On Chip Memory block using the IP catalog
2. Specify the parameters e.g: Width and memory block type (M20K), single clock.
3. I initialized the memory with the MIF file and enabled the In-system memory content editor feature (see the picture).
// Content of MIF file
WIDTH=32;
DEPTH=16384;
ADDRESS_RADIX=HEX;
DATA_RADIX=HEX;
CONTENT BEGIN
00000000 : 1F2F3F4F;
00000001 : 1F2F3F4F;
00000002 : 1F2F3F4F;
00000003 : 1F2F3F4F;
00000004 : 1F2F3F4F;
00000005 : 1F2F3F4F;
00000006 : 1F2F3F4F;
00000007 : 1F2F3F4F;
00000008 : 1F2F3F4F;
4. Added the .IP file and .MIF file to the QSF file.
set_global_assignment -name IP_FILE ../ram_rom/cm33_rom_16384x32.ip
set_global_assignment -name MIF_FILE ../ram_rom/cm33_rom/armRomBootImage.mif
5. After the mapping, I could see my rom1_port_0 instance in the block diagram.
6. I upload the SOF file to the Stratix 10 Fpga (Apollo S10)
7. However, when I try to use the In-system memory content editor tool, I don't see any memory instance, see the picture below.
Am I missing something in this flow ? Does anyone else have seen this problem ?
Kind regards,
Rahul
ShengN_Intel
Tested with Stratix 10 TX and able to see the instance in ISMCE. Check the file and image attached. Does the FPGA being programmed properly?
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
sstrell
Did you try selecting the .sof directly in the ISMCE and programming from there?  Or clicking Scan Chain?
ShengN_Intel
Sheng
Rahul92
Hi Sheng,
Thanks for the files and the screenshot. I did another run and I see the instance now just like your picture.
But, I do have a question. Is it normal to have "Instance ID" as None, even though I give the name as "CM33" while configuring the ROM IP ? I was expecting CM33 as Instance ID instead of None.
Rahul
ShengN_Intel
FYI. Please stick with the workaround below in the mean time:
  1. Go to <Quartus_installed_directory>\ip\altera\sld\jtag\intel_mce\intel_mce_hw.tcl
  2. Change NODE_NAME type from NATURAL to STRING like the following: add_parameter NODE_NAME STRING 0
  3. Regenerate related IP and program.
Sheng
ShengN_Intel
Hi Rahul,
There's a bug with ISMCE instance id. There's no problem on order version Quartus. I'll report this to engineering team.
Sheng
sstrell
The "NONE" instance ID bug has been around for a while.
ShengN_Intel
Hi sstrell,
Yes, the "NONE" instance ID bug has been around for a while since version 20.1. I had reported this to engineering team. Hopefully can get a fix asap.
Sheng
