17160 Discussions
In the MAX 10, I / O pin state before entering user mode can be set by Quartus Prime option "Set I / O weak pull-up prior usemode". So as a question, is it possible to set weak pull-up for each pin?
Blues-sptn
In the "Set I / O weak pull-up prior usemode" setting, it is considered that individual settings can not be made because I / O excluding some are subject. .
AnandRaj_S_Intel
<QUOTE>is it possible to set weak pull-up for each pin.</QUOTE>
All I/O pins are set to week pull up (i.e prior user-mode) during configuration (set using configuration settings).
In user mode the user I/O pins will then function as specified by your design and unused IO pins are week pull up(set using unused pin settings).
Anand
Blues-sptn
Excuse me. How to listen was bad.
Is it possible to individually set the state of the I / O during configuration? For example
Pin_A: Weak pullup enabled
Pin_B: weak pullup invalid
Can we set it? I have recognition that I can not set, but how?
AnandRaj_S_Intel
No, we can not set individually.Setting is common for all pins.
But under user mode we can control enable or disable.
Using Pin Planner tool ->right click on any column header, and select Customize Columns ->under available column select-> Weak Pull-Up Resistor->click add selected column ->click ok. Now back in the Pin Planner window, you should see a new column called Weak Pull-Up Resistor. For each pin you wish to enable it on, simply click in the box for that column and select "On" By default it is turned "Off".
Anand
Blues-sptn
OK.
Thank you for your response.
