I am attempting to infer a single clock, dual port RAM without any bypass logic. I am having problems with synthesis, it seems to add a lot of bypass logic that wasn't there when I used the megawizard.
// Dual-Port RAM with different read/write addresses and single read/write clock
// and with a control for writing single bytes into the memory word; byte enable
// Note - bytes are VERY often not even close to 8 bits. 16 for colors, 18 for floats, etc.
module byte_enabled_dual_port_ram
#(parameter int
RADDR_WIDTH = 8,
WADDR_WIDTH = 6,
BYTE_WIDTH = 8,
BYTES = 4,
WIDTH = BYTES * BYTE_WIDTH
input [WADDR_WIDTH-1:0] waddr,
input [RADDR_WIDTH-1:0] raddr,
input [BYTES-1:0] be,
input [WIDTH-1:0] wdata,
input we, clk,
output reg [WIDTH/(1<<(RADDR_WIDTH - WADDR_WIDTH))-1:0] q
localparam int WORDS = 1 << WADDR_WIDTH;
localparam int RATIO = 1 << (RADDR_WIDTH - WADDR_WIDTH);
// use a multi-dimensional packed array to model individual bytes within the word
logic [BYTES-1:0][BYTE_WIDTH-1:0] ram[0:WORDS-1];
logic [WADDR_WIDTH-1:0] waddr_reg;
logic [RADDR_WIDTH-1:0] raddr_reg;
logic [BYTES-1:0] be_reg;
logic [WIDTH-1:0] wdata_reg;
logic we_reg;
wire [WIDTH-1:0]word = ram[raddr_reg/RATIO];
always_ff@(posedge clk) begin
waddr_reg <= waddr;
raddr_reg <= raddr;
be_reg <= be;
wdata_reg <= wdata;
we_reg <= we;
for(int i = 0; i < BYTES; i++) begin
if(be_reg[i] && we_reg) begin
ram[waddr_reg][i] <= wdata_reg[i*BYTE_WIDTH +: BYTE_WIDTH];
end
end
//q <= ram[raddr / RATIO][(raddr % RATIO) * (BYTES/RATIO) +: (BYTES/RATIO)];
q <= word[(raddr_reg % RATIO) * (WIDTH/RATIO) +: (WIDTH/RATIO)];
end
endmodule : byte_enabled_dual_port_ram
I'm not sure what's going on exactly - when I look at the RTL viewer, I can see that raddr is passed directly to the altsyncram module, instead of going through the raddr_reg:
Any ideas what's gone wrong? How to fix?
Hi Evan,
Apologize for idle for awhile. Do you able to solve the issue? Do you need further help?
I ended up just using an altsyncram definition. I dont think quartus is able to infer such a complicated ram.
