Hi:
Have a problem in installing Quartus with a Ubuntu machine.
Found that the relied package, libncurses6:i386 can't be found.
Is there any solution to fix it?
Best regards
Marco Wu
May I know which Quartus software version you want to install?
Nurina
Hi Nurina:
Quartus Prime Pro 22.4 is my target version.
I tried to install in Ubuntu 20.4. It seems OK because all the linux packages can be installed OK without problem.
Best regards
Marco Wu
Hello Marco,
Knowing that it is working on Ubuntu 20.04, do you still require assistance?
Nurina
Hi Nurina:
Assistance is no need because the problem has been solved with Ubuntu 20.04.
Best regards
Marco Wu
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
