17042 Discussions
Install Quartus on Redhat Enterprise 6.0-x86-64 Fail.
Hello
When I install the Quartus10.sp1 on Redhat Enterprise 6.0-64 Bit System, but return the error:
altera_installer/bin/altera_installer_gui: error while loading shared libraries: libz.so.1: cannot open shared object file: no such file or directory
Is there anyone can help???
Perhaps install zlib? (Compression library)
Cheers,
Dave
Hello dave,
The Install package is perfect, since I could install it on REHL6.0-32-Bit System, however, when I switch to 64-bit system, it does not work any more.
Any suggestions? Thanks.
--- Quote Start ---
--- Quote End ---
Your response is a little confusing. Are you saying that you have the tool working on a 32-bit version of RedHat, but not on a 64-bit version?
I recall having to install ia32-libs on Ubuntu to get it working on a 64-bit OS. Perhaps that is what you need?
Cheers,
Dave
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
This. The installer is 32-bit so it needs the 32-bit zlib library. This worked for me on 64-bit RHEL6:
$ yum install zlib.i686
