17247 Discussions
Integrate DE2 Control Panel to my design
Dear all,
I see that the DE2 Control Panel is too useful.
I would like to integrate it to my design. It means, I want to download
the control panel and my design to the DE2 board at the same time.
I would like to ask the following questions :
1- Can I integrate DE2 source code to my design ?
If yes, how can I do it ? ( I have to look for the RTL source code of DE2 Control Panel and merge it to my design, don't it ? )
2- DE2 Control Pannel is pre-compiled to DE2_USB_API.sof.
Can I download 2 sof files to the board at the same time.
It means I down load my design (after compile to sof file) and DE2_USB_APE.sof to the DE2 board the same time. (By doing it,
I can use Control Panel to monitor the peripheral on board, and also
run my design at this time).
Thank you so much !
Thanh Tran.
