Hi, I am new to Intel HLS and I have version 18.1 lite installed. I tried to run the example programs named loop_memory_dependency and the runtime for calling the build.bat and getting the executable is around 50 minutes. Did I do something wrong? Or is this normal for running under the Windows environment?
Hi ,
It is perfectly normal to have compilation time of loop_memory_dependency example to approach 1 hr.
since it involves conversion C++ code to production quality RTL code,there are many additional operations happening while compared to normal C++ compilation aimed to produce an executable in Windows machine.
Hope that Helps.
Thanks and Regards
Anil
