I was using Intel Quartus Prime Lite for a project. I opened a University Program VWF to simulate my project. Once I set up the option "Node finder" and pressed Run Functional Simulation, it fed me back with an error:
Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
I installed Quartus Prime Lite version 21.1.1, but it did not come with the modelsim_ase. For the simulation to work properly I installed ModelSim 20.1. This solved one problem: Error: Invalid license environment. Application closing.
But then the error aforementioned appeared.
How could I solve this problem from Windows 10?
The Modelsim* - Intel® FPGA Edition (including Starter Edition) will be replaced by the Questa* - Intel® FPGA Edition (including Starter Edition) starting from the Intel® Quartus® Prime Pro Edition Software version 21.3 and Intel® Quartus® Prime Standard/Lite Edition Software version 21.1 onwards. Thus, it is expected that the Quartus Prime Lite version 21.1.1 do not come with the modelsim_ase.
https://www.intel.com/content/www/us/en/support/programmable/articles/000088418.html
Please download the Questa*-Intel® FPGA Edition (including Starter edition) so that it is compatible with the Intel® Quartus® Prime Lite Edition Design Software Version 21.1.1.
You can checkout the forum case below on the solution for the -novopt option error:
Hope it helps.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Hope it helps.
Richard Tan
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
Sure, I was able to solve the problem with the solutions you gave me.
Thank you so much
Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Thank you and have a great day!
Richard Tan
