What's the "125" filter you have enabled on the Assignments tab?
I'm not sure if I/O standard assignments would appear in the Assignments tab of Interface Planner, only location assignments. Try adding a single location assignment in the Pin Planner, then go back into Interface Planner. See if the location assignment you created appears.
#iwork4intel
Hi Serkan,
Either you clear that "125" filter using "Clear option" or reopen the Interface planner & Initialize the Interface Planner.
Vikas
