Problem Details
Error:
Internal Error: Sub-system: FDRGN, File: /quartus/fitter/fdrgn/fdrgn_expert.cpp, Line: 5152
Final postfit netlist check failed
Stack Trace:
Quartus 0x4ca63: `anonymous namespace'::fdrgn_final_check + 0x193 (fitter_fdrgn)
Quartus 0x45d46: FDRGN_EXPERT::check_and_report + 0x316 (fitter_fdrgn)
Quartus 0x12aa9: fit2_write_fitter_report + 0x169 (comp_fit2)
Quartus 0x16442: TclNRRunCallbacks + 0x62 (tcl86)
Quartus 0x17c4d: TclEvalEx + 0x9ed (tcl86)
Quartus 0xa6a8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
Quartus 0xa5136: Tcl_EvalFile + 0x36 (tcl86)
Quartus 0x15246: qexe_evaluate_tcl_script + 0x4e6 (comp_qexe)
Quartus 0x1413b: qexe_do_tcl + 0x46b (comp_qexe)
Quartus 0x1a70e: qexe_run_tcl_option + 0x5ee (comp_qexe)
Quartus 0x146b1: QCU::DETAIL::intialise_qhd_and_run_qexe + 0xa1 (comp_qcu)
Quartus 0x1f8d2: qcu_run_tcl_option + 0x2f2 (comp_qcu)
Quartus 0x1a00b: qexe_run + 0x3eb (comp_qexe)
Quartus 0x1b14a: qexe_standard_main + 0x26a (comp_qexe)
Quartus 0x1fd2: qfit2_main + 0x82 (quartus_fit)
Quartus 0x167e8: msg_main_thread + 0x18 (CCL_MSG)
Quartus 0x17001: msg_thread_wrapper + 0x71 (CCL_MSG)
Quartus 0x21610: mem_thread_wrapper + 0x70 (ccl_mem)
Quartus 0x14b7d: msg_exe_main + 0x20d (CCL_MSG)
Quartus 0x2bc8: __scrt_common_main_seh + 0x11c (quartus_fit)
Quartus 0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
Quartus 0x52650: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: qpro
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.3.0
Build: 158
Edition: Pro Edition
Since you're using the old version of Quartus, we recommend to upgrade the project to the latest Quartus version as there is a lot of fix being done. Kindly update to us if you still encounter the internal error. Thanks.
Ven Ting
The error occurred in Quartus 20.3 pro. I have install the latest Quartus version, but problem didn't fix.
I tried to install VC++2013 redistributable patch, and uninstall Quartus 20.1 standard. Then the problem fixed.
Noted on the changes made. Do you have further question regarding this?
No further question. Thanks a lot
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
