16604 Discussions
Internal Error of zero delay when not expected on Quartus Prime 16.0.2
Hi ,
Quartus Prime version: 16.0.2
Part Number : 10AX115N3F45I2SG
When doing fitter, got below internal error. Pls help, Thx!
Info (11165): Fitter preparation operations ending: elapsed time is 00:04:30
Info (170189): Fitter placement preparation operations beginning
Info (14951): The Fitter is using Advanced Physical Optimization.
Info (170190): Fitter placement preparation operations ending: elapsed time is 00:08:19
Info (170191): Fitter placement operations beginning
Info (170137): Fitter placement was successful
Info (170192): Fitter placement operations ending: elapsed time is 00:06:22
Info (11888): Total time spent on timing analysis during Placement is 79.11 seconds.
Info (170193): Fitter routing operations beginning
Info (170195): Router estimated average interconnect usage is 4% of the available device resources
Info (170196): Router estimated peak interconnect usage is 30% of the available device resources in the region that extends from location X165_Y94 to location X176_Y105
Info (170199): The Fitter performed an Auto Fit compilation. Optimizations were skipped to reduce compilation time.
Info (170201): Optimizations that may affect the design's routability were skipped
Info (11888): Total time spent on timing analysis during Routing is 273.30 seconds.
Info (16607): Fitter routing operations ending: elapsed time is 00:21:02
Info (18289): Started post-fitting delay annotation
Internal Error: Sub-system: PTI, File: /quartus/tsm/pti/pti_tdb_builder.cpp, Line: 1002
IC edge from src atom NIGHTFURY_IOPLL:O_OUTCLK (Id: 2309, with associated RE_GID: 2160385025) to dst atom NIGHTFURY_LCELL_COMB:DATAE (Id: 88120, with associated RE_GID: 4294967295) has zero delay when not expected
Stack Trace:
0x9f134: PTI_TDB_BUILDER::check_ic_edge(CDB_ATOM_ITERM*, TDB_EDGE*) + 0x8b4 (tsm_pti)
0xa4e25: PTI_TDB_BUILDER::build_or_update_tdb_netlist(std::vector<CDB_ATOM_NODE*, std::allocator<CDB_ATOM_NODE*> > const&, TDB_NETLIST_ATOM_DELETOR*) + 0x4a5 (tsm_pti)
0xc4159: PTI_TDB_BUILDER_NIGHTFURY::build_or_update_tdb_netlist(std::vector<CDB_ATOM_NODE*, std::allocator<CDB_ATOM_NODE*> > const&, TDB_NETLIST_ATOM_DELETOR*) + 0x19 (tsm_pti)
0xf42f6: PTI_DELAY_ANNOTATOR::annotate_bcm_netlist(std::vector<CDB_ATOM_NODE*, std::allocator<CDB_ATOM_NODE*> > const&, TDB_NETLIST_ATOM_DELETOR*, bool, bool) + 0x1c6 (tsm_pti)
0xf4bff: PTI_DELAY_ANNOTATOR::annotate_atoms(bool) + 0x38f (tsm_pti)
0xf7572: PTI_DELAY_ANNOTATOR::start(PTI_DELAY_ANNOTATOR::INVOKE_MODE, bool, TDB_TIMING_MODEL, bool) + 0x2d2 (tsm_pti)
0x154fc1: FITCC_TDC_UTILITY::initialize_dat(TAPI_DELAY_ANNOTATOR::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> > const&, bool, bool, bool, QGL::FOREST<int, int>*, bool) + 0x401 (fitter_fitcc)
0x15714d: FITCC_TDC_UTILITY::setup_tdc_utility(TAPI_DELAY_ANNOTATOR::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> >, bool, bool, bool, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool, bool) + 0xa6d (fitter_fitcc)
0x1588d9: FITCC_TDC_UTILITY::FITCC_TDC_UTILITY(FITCC_ENV const*, TAPI_DELAY_ANNOTATOR::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> >, bool, bool, bool, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool, bool) + 0x359 (fitter_fitcc)
0xa869c: FITCC_ENV::get_tdc_utility_or_create_if_necessary(FITCC_ENV::FITCC_TDC_UTILITY_REQUEST_TYPE, TAPI_DELAY_ANNOTATOR::INVOKE_MODE, std::vector<TDB_TIMING_MODEL, std::allocator<TDB_TIMING_MODEL> >, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool) + 0xcac (fitter_fitcc)
0xa8cba: FITCC_ENV::get_tdc_utility_or_create_if_necessary(FITCC_ENV::FITCC_TDC_UTILITY_REQUEST_TYPE, TAPI_DELAY_ANNOTATOR::INVOKE_MODE, dat_timing_models, bool, bool, bool, bool, QGL::FOREST<int, int>*, bool) + 0x1ca (fitter_fitcc)
0x9a1df: FDRGN_AUTO_DELAY_CHAIN_OP::work_new() + 0x12f (fitter_fdrgn)
0x812ae: FDRGN_DELAY_CHAIN_OP::work(FDRGN_DELAY_CHAIN_OP::DELAY_CHAIN_STEP) + 0x32e (fitter_fdrgn)
0x8137e: fdrgn_auto_delay_chain_work(FITCC_ENV*) + 0x2e (fitter_fdrgn)
0x699496: vpr_qi_perform_auto_delay_chain_optimization + 0x46 (fitter_vpr20kmain)
0x804025: aa_flow_finalize + 0x75 (fitter_vpr20kmain)
0x6820f3: VPR_QI_FACADE::finalize() + 0x13 (fitter_vpr20kmain)
0x49717: FDRGN_EXPERT::run_vpr(bool, bool, bool) + 0x1c7 (fitter_fdrgn)
0x4b010: FDRGN_EXPERT::finalize() + 0xa0 (fitter_fdrgn)
0x234c5: fit2_fit_finalize_auto + 0xb8 (comp_fit2)
0x51ec7: TclNRRunCallbacks + 0x47 (tcl8.6)
0x13a5d: fit2_fit_finalize + 0x1f7 (comp_fit2)
0x536e7: TclEvalEx + 0x947 (tcl8.6)
0xfb366: Tcl_FSEvalFileEx + 0x266 (tcl8.6)
0xfb47e: Tcl_EvalFile + 0x2e (tcl8.6)
0x11def: qexe_evaluate_tcl_script(std::string const&) + 0x382 (comp_qexe)
0x18cb0: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x594 (comp_qexe)
0x19c5c: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x57e (comp_qexe)
0x3ccc5: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xeed (comp_qcu)
0x1c496: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6b3 (comp_qexe)
0x3b65: qfit2_main(int, char const**) + 0xc5 (quartus_fit)
0x40360: msg_main_thread(void*) + 0x10 (ccl_msg)
0x602c: thr_final_wrapper + 0xc (ccl_thr)
0x4041c: msg_thread_wrapper(void* (*)(void*), void*) + 0x62 (ccl_msg)
0xb359: mem_thread_wrapper(void* (*)(void*), void*) + 0x99 (ccl_mem)
0x8f98: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x63f2: thr_thread_wrapper + 0x15 (ccl_thr)
0x42622: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xa3 (ccl_msg)
0x1d994: __libc_start_main + 0xf4 (c.so.6)
End-trace
BR
Tony
This is a crash. If it also crashes with Quartus 17 then you will need to raise a ticket with Intel via the mysupport portal.
Have you tried changing the seed number or even the routing effort?
--- Quote Start ---
--- Quote End ---
Hi ,
How to change seed number? Thx!
Tony
Go to Settings --> Compiler Settings --> Advanced Settings (Fitter) --> Fitter Initial Placement Seed
Just change to another number
