17117 Discussions
Introducing delay between output pins
emptysamurai
I want my EPM570 to act as a ring counter and demultiplexer that distributes incoming data to 8 connected devices sequentially. To do that I use a ring counter as an output clock and pass data trough register to output. The problem is that the connected device requires 0.5ns setup time and 1.5ns hold time. Is it possible to ensure this requirement in Quartus?
So far I wrote the following Verilog code (simplified):
module RingCounter(
	input clk,
	input rst,
	input data_in,
	output reg [7:0] counter,
	output reg data_out
always @(posedge clk)
begin
	if (rst)
		counter <= {{7{1'b0}}, 1'b1};
	else
		counter <= {counter[6:0], counter[7]};
	data_out <= data_in;
end
endmodule
And tried to add the following constraints
create_clock -name clock -period 8.33 [get_ports {clk}]
derive_pll_clocks
set_output_delay -clock { clock } -reference_pin [get_ports {counter[0]}]  -min -0.5 [get_ports {data_out}]
set_output_delay -clock { clock } -reference_pin [get_ports {counter[0]}]  -max 1.5 [get_ports {data_out}]
But these constraints produce an error:
Reference pin counter[0] is invalid. It is not clocked by the clock specified in set_input_delay/set_output_delay's -clock option.
As I understand, this error is due to the fact that input clock is not connected directly to none of the outputs (though it obviously drives the counter register). But I don't know how to change my constraints/design to fit above-mentioned requirements.
Any help would be appreciated
AminT_Intel
I think you have to follow what the error suggested. Can you try this code based on the specification from this document? https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max2/max2_mii5v1.pdf
sstrell
Your output delay constraints don't make sense.  You're sort of creating a source synchronous output with counter[0] as the clock, but counter[0] is a data path, not a clock path, for SDC, and it's not based on another clock in the design, as is required for a clock constraint like create_generated_clock.
I guess your best bet would be to set up a relationship between clk (assuming the PLL output clock is not used for this) and counter[0] with a generated clock constraint so perhaps:
create_generated_clock -name clk_out -source [get_ports clk] [get_ports counter[0]] -divide_by 8
set_output_delay  -clock [get_clocks clk_out] -min -0.5 [get_ports {data_out}]
set_output_delay  -clock [get_clocks clk_out] -max 1.5 [get_ports {data_out}]
And normally you would also need this so the path is not analyzed as a data path:
set_false_path -to [get_ports counter[0]]
Does that work?
AminT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
