Hi all,
I find in Altera Opencl the printf() can be used directly in kernel codes but the output order is not guaranteed when multiple work-items are executed simultaneously. So is there any way to enforce the output order? Or is there any way to get a global timer/cycle inside the kernel codes to indicate the activity cycle by cycle? Thanks.Link Copied
