16890 Discussions
Issue in building rocket chip with quartus using litex
arunlee
I am trying to build a rocket based SoC using Litex for terrasic De2 115 FPGA board. There is an issues while building the bitstreams for rocket chip and the issues is detailed in the litex github
https://github.com/litex-hub/linux-on-litex-rocket/issues/36
It looks like the issues could be something with quartus version not liking some chisel generated verilog.
Could you please have a look and suggest some solutions to try.
Could this be an issues of quartus version?
regards
Arun
_AK6DN_
Valued Contributor II
How about you post a sample of the verilog that your Quartus version does not like, and the generated Quartus error messages?
arunlee
Info (12128): Elaborating entity "plusarg_reader" for hierarchy "ExampleRocketSystem:ExampleRocketSystem|SystemBus:subsystem_sbus|TLXbar:system_bus_xbar|TLMonitor:monitor|plusarg_reader:plusarg_reader" File: /home/arun/.local/lib/python3.10/site-packages/pythondata_cpu_rocket/verilog/generated-src/freechips.rocketchip.system.LitexConfig_linux_1_1.v Line: 635
Error (10174): Verilog HDL Unsupported Feature error at plusarg_reader.v(22): system function "$value$plusargs" is not supported for synthesis File: /home/arun/.local/lib/python3.10/site-packages/pythondata_cpu_rocket/verilog/vsrc/plusarg_reader.v Line: 22
Error (12152): Can't elaborate user hierarchy "ExampleRocketSystem:ExampleRocketSystem|SystemBus:subsystem_sbus|TLXbar:system_bus_xbar|TLMonitor:monitor|plusarg_reader:plusarg_reader" File: /home/arun/.local/lib/python3.10/site-packages/pythondata_cpu_rocket/verilog/generated-src/freechips.rocketchip.system.LitexConfig_linux_1_1.v Line: 635
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 2 errors, 329 warnings
    Error: Peak virtual memory: 852 megabytes
    Error: Processing ended: Wed Oct 11 22:46:26 2023
    Error: Elapsed time: 00:00:33
    Error: Total CPU time (on all processors): 00:00:49
Traceback (most recent call last):
  File "/home/arun/litex-boards/litex_boards/targets/terasic_de2_115.py", line 90, in <module>
    main()
  File "/home/arun/litex-boards/litex_boards/targets/terasic_de2_115.py", line 83, in main
    builder.build(**parser.toolchain_argdict)
  File "/home/arun/litex/litex/soc/integration/builder.py", line 367, in build
    vns = self.soc.build(build_dir=self.gateware_dir, **kwargs)
  File "/home/arun/litex/litex/soc/integration/soc.py", line 1332, in build
    return self.platform.build(self, *args, **kwargs)
  File "/home/arun/litex/litex/build/altera/platform.py", line 45, in build
    return self.toolchain.build(self, *args, **kwargs)
  File "/home/arun/litex/litex/build/generic_toolchain.py", line 123, in build
    self.run_script(script)
  File "/home/arun/litex/litex/build/altera/quartus.py", line 216, in run_script
    raise OSError("Error occured during Quartus's script execution.")
OSError: Error occured during Quartus's script execution.
The verilog file is located at https://github.com/litex-hub/pythondata-cpu-rocket/blob/master/pythondata_cpu_rocket/verilog/vsrc/plusarg_reader.v
_AK6DN_
Ok, so here is what I see in the core of that verilog module:
`ifdef SYNTHESIS
assign out = DEFAULT;
`else
reg [WIDTH-1:0] myplus;
assign out = myplus;
initial begin
   if (!$value$plusargs(FORMAT, myplus)) myplus = DEFAULT;
end
`endif
and the error:
which means that the compile variable SYNTHESIS is not set, so the code with the system task $value$plusargs() is being
fed into Quartus to compile. System tasks are in general not synthesizable constructs, so it throws the error, as expected.
You need to define SYNTHESIS to select the synthesizable code vs simulation code.
aikeu
Hi arunlee,
I not able to find any related info for porting the design to a cyclone IV board.
I think we do not have the support for rocket chip design for the cyclone IV board.
Aik Eu
aikeu
Hi arunlee,
I am closing the thread. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Aik Eu
