17195 Discussions
Issue with RTL library compilation for simulation in OpenCL
VE000
I am getting the following error message on compiling RTL library for simulation in OpenCL version 18.1-
aoc: First stage compilation completed successfully.
Compiling for Simulator.
Creating simulation system...
Generating simulation system...
Compiling simulation...
Error: Simulation compile FAILED.
Refer to test/test.log for details.
However there is no test log created.
How do I debug this error?
MEIYAN_L_Intel
May I know do you have done the step according to the https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf in chapter 10.1.8.1?
Also, may I know the information as below:
  1. OS used
  2. OpenCL SDK Edition
VE000
Hi
Thanks for the reply
Yes. Have followed all the steps mentioned in Chapter 10.1.8.1.
OS Used : Ubuntu 18.04
OpenCL SDK Edition : 18.1 Pro
MEIYAN_L_Intel
Could you give the full error message for further investigation?
Also, could you try to run compilation and simulation for example 1 as in Chapter 10.1.9 by follow the instruction in README.html?
Soft reminder: https://fpgasoftware.intel.com/requirements/18.1/, the OpenCL SDK v18.1 is not officially supported in Ubuntu 18.04.
VE000
Hi
The error is not generated. Only these lines are present as an error message.
There are no instructions for simulation of the example 1 in the 'readme.html' file. I am able to successfully compile and EMULATE the example.
MEIYAN_L_Intel
I had reviewed to the README.html, there is stated as below:
To use the simulation flow, the compilation command just needs to be modified slightly:
aoc -march=simulator device/example1.cl -o bin/example1.aocx -I device/lib1 -L device -l opencl_lib.aoclib -board=<board>
Could you try to run the simulator for this example 1?
VE000
Hi
Will check that.
I am giving "a10gx" reference board as the name of the board. Is that OK?
MEIYAN_L_Intel
Yes, the device name is a10gx.
If the example 1 can be simulate without error, could you try to used these command to run simulation to your design?
VE000
HI
On running the example1 based on the instructions in readme.html and chapter 10.1.8.1
Am now getting this error message -
ERROR: No devices found
Querying platform for info:
CL_PLATFORM_NAME                        = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR                      = Intel(R) Corporation
CL_PLATFORM_VERSION                     = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 18.1
Querying device for info:
CL_DEVICE_NAME                          =
CL_DEVICE_VENDOR                        =
CL_DEVICE_VENDOR_ID                     = 32517
Segmentation fault (core dumped)
I have unset the Emulation environment variable - CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA. However the error persists.
MEIYAN_L_Intel
According https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf in chapter 10.1.8.2, do you have set the CL_CONTEXT_COMPILER_MODE_INTELFPGA=3 for the host program to find the simulator device?
VE000
Hi
Yes, I had set the CL_CONTEXT_COMPILER_MODE_INTELFPGA=3 but got that error
MEIYAN_L_Intel
May I know the environment variables that you had set?
Also, may I know the when building RTL library, do the RTL files and other files specified in XML specification file contain charaters other than lower case letters, numbers, periods, underscores and slashes?
