17268 Discussions
Issues to simulate with HPS
Dor_ian
I have an issue when I try to simulate a project with HPS generated on Platform Designer (ex Qsys). When I do a simple generate HDL (just for synthesis), everything is fine and I try a simulation with Questasim (Tools->Run Simulation Tool->RTL Simulation). After Questa is running, all files are compiled and when "vsim" begun, I have errors related to cyclone V HPS modules not defined (see picture). I see no libraries for HPS or modules anywhere on intel directory.
To solve this issue, I try to generate also simulation model on Plateform Designer to help, but i have many issues with that (see file). I don't understand why.
My configuration:
- Windows 10
- Quartus Prime Lite Edition 22.1.1
- Questa Intel starter FPGA 2021.2 (with free license)
If anybody could help me with that, I'll be grateful.
Dorian
Jeet14
I will be working on this forum case.
let me review and check the details shared by you.
Tiwari
Dor_ian
Hi Tiwari,
Do you have some news on my issue ?
Dorian
Jeet14
Apologies for delay.
I am still awaiting for internal reply, I will update you by EOD.
Tiwari
Jeet14
Apologies for delay reply.
The HPS simulation support does not include modules implemented in the HPS, such as the Arm cortex A9 MPCore processor and HPS side peripheral's. Thats the reason you are not able to see the libraries for HPS or modules.
More details are given on below link-
https://www.intel.com/content/www/us/en/docs/programmable/683126/21-2/simulating-the-hps-component.html
Let me know if you have any other query on this.
Tiwari
Dor_ian
I don't use ARM Cortex and all modules I use on my system are supported according to the link your send me.
Some errors I send you seems to be refering to SDRAM but SDRAM should be normally supported, so I don't understand.
May it be something else ?
Dorian
Jeet14
Is it possible to share the project?
Tiwari
Dor_ian
I sent you a PM with .qar file.
Dorian
Jeet14
I am not able to see the attachments in PM.
can you please resend with attachments.
Tiwari
Jeet14
I received the shared .qar file.
Please allow me some more time to go through this. I will update you ASAP.
Tiwari
Jeet14
We have reproduced the issue at our end.
It is taking some more time as I am awaiting for the reply from the factory app team. I will update you ASAP.
Tiwari
Jeet14
I checked with the backend team they are working on this issue to add the additional file to the synthesis path to enable this module.
Tiwari
Jeet14
Sorry, there is delay in resolving this issue from our end.
Backend team is working on this issue. I will try to update by this weekend.
Tiwari
Jeet14
Apologies for the delay in getting the resolution for your issue.
I had sent the private email, kindly check and let me know if you have any other query on this matter.
Tiwari
Jeet14
I believe your issue has been answered. With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
