16228 Discussions
It's possible to retrieve the vhdl code from the .pof file? if so, how?
nicoh
ak6dn
Valued Contributor III
For all practical purposes, no. Not possible.
Theoretically if one knows the exact encoding of a .pof file for a particular device, one could write a disassembler that built a gate level connectivity list of logic cells. And that could be represented in VHDL.
But .pof file format is not public information. And the generated VHDL netlist would be a full chip gate level netlist. Not so useful.
So if you have a .pof file but lost the source VHDL you are out of luck.
nicoh
ak6dn
Nope.
.pof files are for for non-volatile CPLD devices, .sof files are for volatile SRAM based FPGA devices.
But the same issues apply.
hareesh
Hi @nicoh,
I think you got solution to your issue. If you don't have any another quires I'll close the case. pls confirm.
