16014 Discussions
JTAG Chain Debugger - Replay SVF
BHoey
Is there a way to run a SVF file in the JTAG Chain Debugger that will display the readback values?
I can get Info messages saying the file was successfully run but cannot see what was read back on TDO.
-Brian
Ash_R_Intel
Please check for the task 'Playback the debugging sequence' on the following webpage:
https://www.intel.com/content/www/us/en/docs/programmable/683039/21-3/jtag-chain-debugging-tab-53534.html
BHoey
The issue is that the message window does not echo the commands or show what came back via TDO.  If the script fails it does not indicate where.
Ash_R_Intel
Found some good videos demonstrating the usage of SVF file in JTAG chain debugger tool:
https://www.youtube.com/watch?v=C_hh31u3Fdc
https://www.youtube.com/watch?v=3xKB72SBOp4
Request you to please refer them.
BHoey
These videos really don't show using the SVF at all.  The playback function is limited.  It does not print to screen what was read back.
