16226 Discussions
¿Las señales no funcionan con los operadores aritmeticos?
RGuzm4
Buenas tardes, estoy intentando implementar un multiplicador de palabra en Quartus II 13.0 sp1, cuando le doy un valor (dado por una operacion de multiplicacion) a una salida, la muestra bien, pero si le doy el mismo valor a una señal, no muestra nada, no se por qué, adjunto imagen para que se vea lo que sucede.
La salida es "numero" y la señal es "c1"
Vicky1
please ensure the below things,
  1. Go to "Simulation" -> "option" -> "Quartus II simulator"
  2. Then "Simulation" -> "Run Functional Simulation" another simulation waveform editor window will open where you can check the result.
Refer the screenshot,
let me know, if you have any different concern.
Vikas
Vicky1
Have you resolved the issue?
Should I consider to be case closed?
Vicky
RGuzm4
sorry it took me long in answer, i couldn't solve the problem, but it's just a simulation problem, in the fpga it worked just fine, thanks for answering
Vicky1
Have you checked my previous post?
I was able to do simulation successfully so please check & provide screenshot too.
what you observed during simulation?
Vicky
