16556 Discussions
Latches in frequecny divider using fsm implementation
I am new to verilog and HDL.
I want to implement a N-frequency divider,
which count clock ticks (pos and neg) and start the counting mechanism from the first rising edge of the input clk.
In addition the clk divider has to support synchronous rst_n.
I am using Altera Quartus and the following code
https://pastebin.com/mkw686h4
module clk_divider_fsm ( in_clk, rst_n, out_clk ); input in_clk, rst_n; output out_clk; parameter prescaler = 10; parameter BIT_DEPTH = `CLOG2(prescaler); parameter S0 = 2'b00, S1 = 2'b01, S2 = 2'b10; parameter CNT_RESET = {BIT_DEPTH{1'b0}}; //parameter CNT_FIRST = {BIT_DEPTH-1{1'b0}, 1'b1}; reg ps, ns; reg out_change; reg out; reg cnt; initial begin ps = S0; ns = S0; cnt = CNT_RESET; out_change = 1'b0; out = 1'b0; end always @ (in_clk) begin if(!rst_n) ps = S0; else ps = ns; // begin // if(ns != ps) // ps = ns; // end end always @ (in_clk) begin case(ps) S0: begin if(in_clk === 1'b1) begin out_change <= 1'b1; ns <= S1; cnt <= CNT_RESET + 1'b1; end else begin out_change <= 1'b0; cnt <= CNT_RESET; ns <= S0; end end S1: begin if(in_clk === 1'b0) begin if(cnt == prescaler) begin cnt <= CNT_RESET + 1'b1; out_change <= 1'b1; ns <= S2; end else begin cnt <= cnt + 1'b1; out_change <= 1'b0; ns <= S2; end end else begin out_change = 1'b0; ns = S1; cnt <= cnt; end end S2: begin if(in_clk == 1'b1) begin if(cnt == prescaler) begin cnt <= CNT_RESET + 1'b1; out_change <= 1'b1; ns <= S1; end else begin cnt <= cnt + 1'b1; out_change <= 1'b0; ns <= S1; end end else begin out_change = 1'b0; ns = S2; cnt <= cnt; end end default: begin out_change <= 1'b0; cnt <= CNT_RESET; ns <= S0; end endcase if(!rst_n) begin ns <= S0; cnt <= CNT_RESET; end end always @ (posedge out_change or negedge rst_n) begin if(!rst_n) out <= 1'b0; else out <= ~out; end assign out_clk = (prescaler == 1) ? (in_clk & rst_n) : out; endmodule
After synthesis I get warnings about latches used for cnt register.
What am I doing wrong?
Can you guide me with good practice tips to avoid such cases in the future or more elegant ways to implement those kind of RTL?
thanks
Please can you re-post the code with some line feeds/carrige returns?
I edited the post, however the post cannot be seen right now.
Here is the code:
in_clk,
rst_n,
out_clk
output out_clk;
reg [1:0] ps, ns;
reg out_change;
reg out;
reg [BIT_DEPTH:0] cnt;
initial
begin
ps = S0;
ns = S0;
cnt = CNT_RESET;
out_change = 1'b0;
out = 1'b0;
end
always @ (in_clk)
begin
if(!rst_n)
ps = S0;
else
ps = ns;
// begin
// if(ns != ps)
// ps = ns;
// end
end
always @ (in_clk)
begin
case(ps)
S0: begin
if(in_clk === 1'b1)
begin
out_change <= 1'b1;
ns <= S1;
end
else
begin
out_change <= 1'b0;
cnt <= CNT_RESET;
ns <= S0;
end
end
S1: begin
if(in_clk === 1'b0)
begin
begin
out_change <= 1'b1;
ns <= S2;
end
else
begin
cnt <= cnt + 1'b1;
out_change <= 1'b0;
ns <= S2;
end
end
else
begin
out_change = 1'b0;
ns = S1;
cnt <= cnt;
end
end
S2: begin
if(in_clk == 1'b1)
begin
begin
out_change <= 1'b1;
ns <= S1;
end
else
begin
cnt <= cnt + 1'b1;
out_change <= 1'b0;
ns <= S1;
end
end
else
begin
out_change = 1'b0;
ns = S2;
cnt <= cnt;
end
end
default: begin
out_change <= 1'b0;
cnt <= CNT_RESET;
ns <= S0;
end
endcase
if(!rst_n)
begin
ns <= S0;
cnt <= CNT_RESET;
end
end
begin
if(!rst_n)
out <= 1'b0;
else
out <= ~out;
end
endmodule
You should use
Always @(posedge in_clk)
Using levels of in_clk will give you latch.
Thank you for your reply.
I want to count both clk rising and falling edges.
You can't do that in FPGA. Easiest way to do that would be with a 2x clock
Hi Tricky, thank you for your reply
Is it possible to use 2 different counters
one for rising edges and one for falling edges
and combine those two counters?
or that cant be achieved neither when using FPGA?
In addition,
Quartus manage to synthesis this module without errors.
Why it's not possible to have both edges of a signal in sensitivity list?
Registers in an FPGA only have a single clock input, hence one register can only use a single clock, either a rising or falling edge.
You may be able to separate the counters, but they will be in separate clock domains and combining them will not be so trivial. Much easier just to use a 2x clock.
Hi Tricky, thank you for your reply.
I have seen some code examples where the signals in sensitivity list are written without any edge statements.
Such code can be synthesized ?
Why quartus doesn't raise any error if such implementation is not compatible with FPGAs?
--- Quote Start ---
--- Quote End ---
Thats because those blocks will describe assignments for the variables in ALL paths through the block (ie. assigned in all ifs and else), so no latches are created.
OK, but as you said previously
FPGAs doesn't support both falling and rising edges of signal.
is that means every verilog module targeted for FPGA can't have sensitivity list without stating the edge of the signal?
--- Quote Start ---
--- Quote End ---
Your code is not clocked, it is level sensitive, hence the latches.
If you wanted to be sentive to the edges, you would write:
always @(posedge clk or negedge clk) begin if (clk = '1') //rising edge action else if (clk = '0') // falling edge action end
This would create a double edge sensitive flop, which is not possible in FPGA. The following code is just level sensitive to the compiler, but not simulation as quartus will ignore the signals in the sensitivity list, and just use what is in the always block, so will not produce a flop:
always @(clk) begin if (clk = '1' ) // stuff to do while clock is '1' else if (clk = '0') // stuff do while clock is '0' end
Hi Tricky,
If I get it right,
always @(clk)
begin
end
or always @(*)
are supported for compilation only but not for simulation and programming into FPGAs.
Am I correct?
--- Quote Start ---
Hi Tricky,
If I get it right,
always @(clk)
begin
end
or always @(*)
Am I correct?
--- Quote End ---
Incorrect.
They are a legitimate way of coding verilog, for creating logic or latches, which are both suitable for FPGAs.
Hi Tricky,
writing
always@(clk)
means it will execute the process for each changing in clk signal, in other words sesitivity for both rising or falling edges. However as you said FPGAs doesn't support dual edge flip flops. What am I missing?
Sorry, I really don't get it when dual edge sensing is valid and when it's not. And why I don't get any synthesis errors if the HDL code is not suitable for the target device?
FPGAs do not support dual edge flip flops. Plus Synthesis tools (but not simulators) ignore the sensitivity list of the always block. Hence, if you write:
always @(clk)
The synthesis tool ignores it, and treats it as
always @(*)
This is because synth tools have to infer logic from your code, and have to follow specific templates to generate specific logic.
See https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-handbook.pdf , section 2-12 for recommended HDL coding styles.
The problem with writing
always @(clk)
Is that in simulation it will behave like a dual edge flop, but as synthesis treats it as always @(*), the simulation behaviour and real hardware behaviour will not match. This is why you get warnings about latch generation when you may have a perfectly good simultion.
Thank you Tricky
