I have a question about the license,
how can I check which FPGA families are supported by the license file that I have currently in use? ThanksLink Copied
in general, supported devices aren't called out in the license file. Quartus II Web Edition only has support for limited families while Subscription Edition supports all families:
http://www.altera.com/literature/po/ss_quartussevswe.pdf there are some rare exceptions of older devices or families that require a separate license entry but i can't remember specifics- Mark as New
i saw your other thread, there shouldn't be any problems targeting Cyclone II
which IP are you using that require a license?- Mark as New
--- Quote Start --- i saw your other thread, there shouldn't be any problems targeting Cyclone II which IP are you using that require a license? --- Quote End --- It's weird, Im not using any IP, I just did the tutorial "4. Primitive library tutorial" from the "Handbook DSP vol.3". Modelsim works perfectly, then when I try to launch the Compilation in Quartus I get a message saying that I dont have the license of that FPGA family
if you attach a small example project i can take a look
--- Quote Start --- if you attach a small example project i can take a look --- Quote End --- Do you mean the .mdl file or all the files after the simulation?
