How do you list all of the pins of a design in the pin planner? I'm not looking for the physical FPGA pins, i mean the actual design we've created. I've deleted a couple of pins/nodes at the bottom of the pin planner by accident. I know i can create a new node and type the node name back in but i'm wondering if there is a button that i can click, that will list all of the pins/nodes within the design?Link Copied
If you recompile your design (I think the "analysis and synthesis" step is enough) and go back in the pin planner, the unmapped pins will appear again in the list and you can assign them back.
