I am trying to write my own LVDS receiver (I can not use the standard one).
4 lvds lines, frequency 74.25 MHz, deserialization factor 7.
ALTDDIO_IN_component : ALTDDIO_IN
GENERIC MAP (
intended_device_family => "Cyclone V",
invert_input_clocks => "OFF",
lpm_hint => "UNUSED",
lpm_type => "altddio_in",
power_up_high => "OFF",
width => 4
PORT MAP (
datain => Serial_Data,
inclock => Signal_FastClock,
dataout_h => Signal_Data_D
PROCESS( Signal_FastClock )
BEGIN
IF( RISING_EDGE( Signal_FastClock ) ) THEN
Signal_Data_Q <= Signal_Data_D;
FOR I IN 0 TO 3 LOOP
Signal_ShiftData( I ) <= Signal_ShiftData( I )( 5 DOWNTO 0 ) & Signal_Data_Q( I );
END LOOP;
END IF;
END PROCESS;
Signal_ShiftData is ARRAY( 0 TO 3 ) OF STD_LOGIC_VECTOR( 6 DOWNTO 0 );
Signal_FastClock is 519.75MHz
How can I describe this path so that it is fitted correctly? dataout_h[3] is ok
Hi Evgeniy!
First of all, thank you so much for reaching us.
My name is Eliath and I'll help you with the issue.
Please, could you tell me if you had some problems using our LVDS? or why you couldn't use it?
I'll need to review your project to see what exactly is happening and try to help you so...
Could you please share it with me please?
-Eliath Guzman
Hi!
We can not use standard lvds receivers because we have three receivers in one bank.(prev ask)
The whole project is very large, I can throw off the receiver itself
Try to use Long Path Tool, it really can help you with that.
It will really help you to solve your problem.
It will really help you to solve your problem.- ( Tom Murphy )
For more complete information about compiler optimizations, see our Optimization Notice.
