i need to implement the Low Latency 100G Ethernet IP in my design. I need the HARD IP version, but Quartus keeps implementing the soft IP.
What do i have to do in order to use the HARD one?
You selected the wrong Ethernet IP. :)
Low Latency 100G Ethernet Intel Stratix 10 - is soft Ethernet IP
For hard 100G Ethernet IP solution, you can consider either options below
- Intel® FPGA H-Tile Hard IP for Ethernet
- E-Tile Hard IP for Ethernet Intel FPGA IP
I recommend you to checkout below link to find out
more info on all different Ethernet IP solution supported by Intel FPGA.
- https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/ether...
dlim
HI,
I have not hear back from you after provided explanation on the Ethernet IP solution.
Hopefully my explanation is clear to you.
For now, I am setting this case to closure.
dlim
