AN745 in "Table 1. I/O Standards for MIPI D-PHY Implementation" requires "Differential HSTL-1.8" for high speed pins. However Quartus compilation fails...
According to the MAX10 device handbook, the chip supports "Differential HSTL-1.8".
Is this feature available for all high speed pins?
Thank you
Yes you can refer to page 22 from this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
Hi AminT
thank you for your reply.
Indeed the document specify the VOL/VIH ranges, but it seems not referring to which set of IOs support Differential HSTL.
Is there any clarification on that?
Would all the pin marked as DIFFIO / DIFFIO_TX / DIFFIO_TX_RX support Differential HSTL?
Thank you
It depends. You may refer to pin-out files from this link of your device: https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
Thank you.
Hi Amin,
thank you for the hint. For instance, that means pins marked
DIFFIO_RX_L5n
DIFFIO_RX_L6n
are not differential TX/RX but just differential RX capable pins, correct?
Thank you
Yes you are right!
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
For more complete information about compiler optimizations, see our Optimization Notice.
