Hey everyone
I'm at the very beginning of a project where I want to implement a power converter digital controller on a MAX10 device. I have a little experience, but only with Lattice FPGAs and tools.
I'm using the MAX1000 development board with a 10M08SAU169C8G and Quartus Prime 20.1.
As a start I've implemented a binary counter using the on-board 12MHz oscillator and 8 LEDs. It works but I get the following warning, that I would like to handle:
Info (169124): Fitter converted 4 user pins into dedicated programming pins
Info (169125): Pin ~ALTERA_TMS~ is reserved at location G1
Info (169125): Pin ~ALTERA_TCK~ is reserved at location G2
Info (169125): Pin ~ALTERA_TDI~ is reserved at location F5
Info (169125): Pin ~ALTERA_TDO~ is reserved at location F6
Info (169141): DATA[0] dual-purpose pin not reserved
Info (12825): Data[1]/ASDO dual-purpose pin not reserved
Info (12825): nCSO dual-purpose pin not reserved
Info (12825): DCLK dual-purpose pin not reserved
Warning (15714): Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details
Seems it first complains about the JTAG pins, but after that about another (or the same?) 4 dual-purpose pins.
Does anybody know what I'm supposed to do here?
Also there is a warning, that I didn't specify timing constraints:
Critical Warning (332012): Synopsys Design Constraints File file not found: 'counter.sdc'. A Synopsys Design Constraints File is required by the Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
Can somebody point me to a tutorial for a starting point how to do this?
Many thanks and all the best
Gaston
meassage lines starting with "info" are no warnings, just processing information. The warning about incomplete I/O assignments can be traced in the Fitter report/Resource Section/I/O Standards Section/I/O Assignments Warnings. You'll find hints like missing drive strength or missing location assignment for specific pins.
You should have a .sdc file that at least declares the pin and frequency of your clock input. This enables the timing analyser to check the internal timing of your design.
Frank
This is what I find in the I/O Assignment Warnings:
This is the list in pin planner:
The assignment editor:
And the top vhdl:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use work.Counter_pack.all;
entity counter is
port (
ResetxSBI : in std_logic;
ClkxCI : in std_logic;
LedxDO : out std_logic_vector(7 downto 0)
end counter;
architecture behavioral of counter is
signal CountValuexD : unsigned(COUNTER_WIDTH-1 downto 0); -- count value
begin
CntStateMachine: process (ClkxCI,ResetxSBI)
begin
if ResetxSBI = '0' then
CountValuexD <= to_unsigned(0,COUNTER_WIDTH);
elsif ClkxCI'event and ClkxCI = '1' then
-- determine next counter value
CountValuexD <= CountValuexD + to_unsigned(1,COUNTER_WIDTH);
end if;
end process CntStateMachine;
-- assign outputs
LedxDO <= std_logic_vector(CountValuexD(COUNTER_WIDTH-1 downto COUNTER_WIDTH-8));
end behavioral;
The mesage incomplete set of assignments seems to refer to the only two inputs of the design. The outputs seem to be OK. But I don't understand what's missing.
clk_clk and reset_reset_n don't even appear in your design. Do you have any idea where these are coming from?
Do you still the warning massage in the I/O Assignment Warnings?
