16335 Discussions
MAX10 GPIO Lite DDR Output Sim
BOnor
I've run into the follow error while initializing an Aldec simulation:
ELBREAD: Error: ELBREAD_0081 fiftyfivenm_atoms_ncrypt.v (732): Design unit protected_97b98e91bb4cae2ac97c0cd96c2469e5 instantiated in fiftyfivenm_ver.protected_c1a23861916f90f6e0d08a9e524674ac1a53e8ab8a67ecf4fe70c175c8a05438 not found in searched libraries: fiftyfivenm_ver, MaxGpioSim.
I have been successful simulating a gpio lite input (single FF).
Any help would be greatly appreciated.
-Brian
Abe
Valued Contributor II
Have you compiled the device libraries for Aldec simulator using Quartus Library compiler prior to performing the RTL simulation ? Try re-compiling the FPGA libraries and then simulating.
MuhammadAr_U_Intel
Hi Brian,
Please note the version of ALDEC simulator tested with Quartus.
https://www.intel.com/content/www/us/en/programmable/documentation/gtt1529956823942.html
Table 1. Supported Simulators
Since you mentioned you are able to simulate GPIO Lite Single input FF, I am suspecting above Error message is due to missing Libraries
Can you try following.
  • Use the auto-generated simulation script to bring up IP simulation.
If the issue still persists you can share further details with me to take a look.
  • Quartus Version used to Generate IP and simulation libraries.
  • What version of ALDEC simulator are you using ?
  • GPIO settings (If possible share the project archive)
  • What steps did you followed to replicate Error ?
Arslan
BOnor
I have already tried to use the auto-generate simulation script which creates and compiles all of the required libraries.
I've also tried the pre-compiled Aldec libraries. Same results in both cases.
When the issue first started I was using Active-HDL 10.3 and Quartus 17.0.
Then I updated to the latest of both tools: Active-HDL 10.5a.12.6914 and Quartus 18.1.0
gpoutputddr_inst : component altera_gpio_lite
generic map (
PIN_TYPE                 => "output",
SIZE                   => 1,
REGISTER_MODE              => "ddr",
BUFFER_TYPE               => "single-ended",
ASYNC_MODE                => "clear",
SYNC_MODE                => "none",
BUS_HOLD                 => "false",
OPEN_DRAIN_OUTPUT            => "false",
ENABLE_OE_PORT              => "false",
ENABLE_NSLEEP_PORT            => "false",
ENABLE_CLOCK_ENA_PORT          => "false",
SET_REGISTER_OUTPUTS_HIGH        => "false",
INVERT_OUTPUT              => "false",
INVERT_INPUT_CLOCK            => "false",
USE_ONE_REG_TO_DRIVE_OE         => "false",
USE_DDIO_REG_TO_DRIVE_OE         => "false",
USE_ADVANCED_DDR_FEATURES        => "false",
USE_ADVANCED_DDR_FEATURES_FOR_INPUT_ONLY => "false",
ENABLE_OE_HALF_CYCLE_DELAY        => "true",
INVERT_CLKDIV_INPUT_CLOCK        => "false",
ENABLE_PHASE_INVERT_CTRL_PORT      => "false",
ENABLE_HR_CLOCK             => "false",
INVERT_OUTPUT_CLOCK           => "false",
INVERT_OE_INCLOCK            => "false",
ENABLE_PHASE_DETECTOR_FOR_CK       => "false"
port map (
outclock    => outclock, -- outclock.export
din       => din,   --   din.export
pad_out     => pad_out, -- pad_out.export
aclr      => aclr,   --   aclr.export
outclocken   => '1',   -- (terminated)
inclock     => '0',   -- (terminated)
inclocken    => '0',   -- (terminated)
fr_clock    => open,   -- (terminated)
hr_clock    => open,   -- (terminated)
invert_hr_clock => '0',   -- (terminated)
phy_mem_clock  => '0',   -- (terminated)
mimic_clock   => open,   -- (terminated)
dout      => open,   -- (terminated)
pad_io     => open,   -- (terminated)
pad_io_b    => open,   -- (terminated)
pad_in     => "0",   -- (terminated)
pad_in_b    => "0",   -- (terminated)
pad_out_b    => open,   -- (terminated)
aset      => '0',   -- (terminated)
sclr      => '0',   -- (terminated)
nsleep     => "0",   -- (terminated)
oe       => "0"    -- (terminated)
Thanks for the support!
-Brian
BOnor
Hi All,
I just solved this issue by adding altera_ver to the Verilog Libraries (-L) which is used by asim.
Not sure why this is was needed but a least now I can make progress.
-Brian
MuhammadAr_U_Intel
Hi Brian,
"altera_ver" is a Altera simulation library for Verilog similarly there is one for VHDL "altera" and is needed to simulate the IP. I am wondering if this is not part of auto-generated script.
I am glad you are able to proceed.
Arslan
