using questa 2019.1
after running
vopt -reportprogress 300 tb_top "+acc=npr3" -o mydesign_opt -L fiftyfivenm_ver -L altera_mf_ver -L altera_ver -L lpm_ver -L altera_lnsim_ver
I got error
# ** Error: C:/tools/intelFPGA/17.0/quartus/eda/sim_lib/mentor/fiftyfivenm_atoms_ncrypt.v(38): in protected region
this is only for using ddio_out for MAX10 GPIO .
the ddio_in is simulated OK .
I compiled all the lib needed.
help will be welcome
Rami
Hi ,
Can you please check all the libraries got correctly.
MAX10 GPIO Lite DDR Output cant be simulated in modelsim 10.1d. It is showing same problem that is showed aboved.
Please give solution for it.
