17267 Discussions
Macros with arguments and default value in SystemVerilog
uea999
It seems Quartus Prime can't support default value in a macro, i.e., the following code will report error with illegal character in macro parameter near "='0)" using standard version 18.1. However if i remove the default value (which is ='0 ) from the macro then there will be no complaints from the compiler.
We would like to keep the default value so that we can use this macro with`ffr_arst(somereg_q,somereg_d,clk_i, rst_i) for most of our cases. May i know if there is a solution for this?
`ifndef ffr_arst
`define ffr_arst(Q, D, Clk, Rst, InitValue='0) \
    initial Q = InitValue; \
    always_ff @(posedge Clk or posedge Rst) begin \
        Q <= (Rst) ? InitValue : D; \
    end
`endif
`ffr_arst(somereg_q,somereg_d,clk_i, rst_i,'0)
ShengN_Intel
Hi @uea999 ,
This feature is supported in pro version but not standard version check image below:
Hopefully answering your doubts.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
ShengN_Intel
Hi @uea999 ,
Sheng
uea999
Thank you @ShengN_Intel , that answered my question.
