Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
MegaWizard 2x8k Dual Port Memory
Try to Convert a Project to Cyclone III but need Help with the Memory Type
Orginal Code
module vidram( output data_out, // cpu interface input data_in, input cpu_addr, input we, output video_data, // video hardware intf input video_addr, input clk ); // A single Spartan 8x2k 2-port RAM. Easy. RAMB16_S9_S9 ram(.DIA(data_in), .DIPA(1'b0), .DOA(data_out), .DOPA(), .ADDRA(cpu_addr), .WEA(we), .ENA(1'b1), .SSRA(1'b0), .CLKA(~clk), // see description .DIB(8'h00), .DIPB(1'b0), .DOB(video_data), .DOPB(), .ADDRB(video_addr), .WEB(1'b0), .ENB(1'b1), .SSRB(1'b0), .CLKB(~clk) // see description ); endmodule // vidram
Mega Wizard generates me
module vidram ( clock, data, rdaddress, wraddress, wren, q); input clock; input data; input rdaddress; input wraddress; input wren; output q; `ifndef ALTERA_RESERVED_QIS // synopsys translate_off `endif tri1 clock; tri0 wren; `ifndef ALTERA_RESERVED_QIS // synopsys translate_on `endif wire sub_wire0; wire q = sub_wire0; altsyncram altsyncram_component ( .address_a (wraddress), .clock0 (clock), .data_a (data), .wren_a (wren), .address_b (rdaddress), .q_b (sub_wire0), .aclr0 (1'b0), .aclr1 (1'b0), .addressstall_a (1'b0), .addressstall_b (1'b0), .byteena_a (1'b1), .byteena_b (1'b1), .clock1 (1'b1), .clocken0 (1'b1), .clocken1 (1'b1), .clocken2 (1'b1), .clocken3 (1'b1), .data_b ({8{1'b1}}), .eccstatus (), .q_a (), .rden_a (1'b1), .rden_b (1'b1), .wren_b (1'b0)); defparam altsyncram_component.address_aclr_b = "NONE", altsyncram_component.address_reg_b = "CLOCK0", altsyncram_component.clock_enable_input_a = "BYPASS", altsyncram_component.clock_enable_input_b = "BYPASS", altsyncram_component.clock_enable_output_b = "BYPASS", altsyncram_component.intended_device_family = "Cyclone III", altsyncram_component.lpm_type = "altsyncram", altsyncram_component.numwords_a = 2048, altsyncram_component.numwords_b = 2048, altsyncram_component.operation_mode = "DUAL_PORT", altsyncram_component.outdata_aclr_b = "NONE", altsyncram_component.outdata_reg_b = "CLOCK0", altsyncram_component.power_up_uninitialized = "FALSE", altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE", altsyncram_component.widthad_a = 11, altsyncram_component.widthad_b = 11, altsyncram_component.width_a = 8, altsyncram_component.width_b = 8, altsyncram_component.width_byteena_a = 1; endmodule
but i need 2 Output Lines
Highlighted
You need to select "two read/write ports" on the very first MegaWizard page.
Highlighted
I had this idea already, but how do I have to assign
orginal
module vidrama( output data_out, // cpu interface input data_in, input cpu_addr, input we, output video_data, // video hardware intf input video_addr, input clk ); .... vidrama vidram( .data_out(vram_data), .data_in(data_in), .cpu_addr(addr), .we(vram_we), .video_addr(video_addr), .video_data(video_data), .clk(clk) );
changed to
module vidrama ( address_a,//cpu_addr, address_b,//video_addr, clock,//clk data_a,//data_in, data_b,//data_in, wren_a,//we, wren_b,//we, q_a,//data_out, q_b//video_data, ); ..... vidrama vidram( .data_a(data_in), .data_b(data_in), .address_a,(addr), .address_b,(video_addr), .wren_a(vram_we), .wren_b(vram_we), .q_a(vram_data), .q_b(video_data), .clock(clk) );
will not work
Highlighted
--- Quote Start ---
will not work
--- Quote End ---
No, why don't you copy the original port assignment, e.g. disable wren_b?
Highlighted
Sorry for German but my English is very Bad.
Kannst du vielleicht bitte mal drüber schauen und mir den Weg zeigen ich bekomm es nicht hin
Original Files
http://www.share-online.biz/dl/wmw069hot6m
