Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition (Linux) on Ubuntu 18.04 is working until:
- Select IP Catalog using PLL as a search,
- Select ALTPLL, the megaWizard Plugin Manager pops up,
- change inclk0 value, the dialog locks up. Any user input locks up the GUI
Agreed, if it is resized before any input is done there is no lockup. That was my reply 15 days ago...
OK, will try several others.
Try do not resize MegaWizard window.
I had same problem with some.
Seems that most MegaFunction do lockup at some point,when an input changes the dialog size. I did try LPM_MUX, changed the number and was allow to progress to the next screen, but locks up after that.
Make sure your Java is up-to-date.
Have the openkdk installed: openjdk 10.0.2 2018-07-17
If the window is enlarged in the horizontal direction there is no lockup.
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
