I have designed a logic circuit in Quartus Lite 18.1 and I`d like to make it a primitive so that I could use it in my designs. How do I do that properly?
On the Internet I have found many references to the tool called MegaWizard, which seems to be doing just what I need, shipped with Quartus Lite. However, the Tools menu in my Quartus install lacks the proper item.
Where should I look for that MegaWizard tool?
"I have designed a logic circuit in Quartus Lite 18.1 and I`d like to make it a primitive so that I could use it in my designs. How do I do that properly?" ---- similar functionality you can get using creating custom component or IP, please refer the the links below,
https://www.youtube.com/watch?v=AN6cs4mJmpo
https://www.youtube.com/watch?v=v6rhbVABlo8
"Where should I look for that MegaWizard tool?" ------ In Quartus Lite 18.1 you can find the similar functionality like Megawizard in Platform Designer under Tools menu..
https://www.intel.com/content/www/us/en/programmable/products/intellectual-property/megawizard.html
please let me know if you have any different issue.
Vicky
Vicky
May I know any update or should I consider that case to be closed?
Vicky
