I am using Quartus 14.0 subscription edition on Ubuntu. I can not find the MegaWizard plug-in manager anywhere. Has anyone had this problem? or have any suggestions please. Thanks PaulLink Copied
The MegaWizard is no more.
http://www.altera.com/literature/ug/ug_intro_to_megafunctions.pdf (If you have stuff that was a MegaFunction and doesn't show up in the IP tab of the project navigator, you can do File -> Open, and when it opens you will see the MegaWizard.)- Mark as New
--- Quote Start --- The MegaWizard is no more. --- Quote End --- In which case, is there a revised 'my first fpga' tutorial that doesn't require this megawizard to configure the pll and the output mux?
Rysc,
HI, were you able to configure the IP Catalog? I modified the Tools>Options>Ip Catalog> IP Catalog Search Locations to point to the Altera\14.0\ip\altera but I'm still not able to get it to work. joe- Mark as New
Rysc,
HI, got it to work. The window popped up on the right of my screen and I didn't notice it until now. joe- Mark as New
When I try to add in an "altpll" the MegaWizard did not finish loading. Any ideas?
