Memory Access violation
Hi All,
I am trying to get my code o compile, which it has been doing fine all morning, but now I am consistently getting stack failures as detailed below. Can anyone help me understand what these errors mean and how to fix/avoid them?
*** Fatal Error: Access Violation at 0X000007FAE5D72D21
Module: quartus_map.exe
Stack Trace:
0x2d20: PDB_SEMAPHORE::create + 0x1190
0x34121: CDB_SGATE_COMP_PORT_ENTRY::operator<< + 0x91
0x529b: pdb_write_ptr + 0xfb
0x1075c3: sgn_clear_check_ip_functor + 0x6a953
0x1152a0: sgn_clear_check_ip_functor + 0x78630
0x9f64d: sgn_clear_check_ip_functor + 0x29dd
0xae656: sgn_clear_check_ip_functor + 0x119e6
0xb9dda: sgn_clear_check_ip_functor + 0x1d16a
0xba15b: sgn_clear_check_ip_functor + 0x1d4eb
0x10de2: sgn_qic_full + 0x152
0x128ed: qexe_get_command_line + 0x206d
0x1573e: qexe_process_cmdline_arguments + 0x59e
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x1841: BaseThreadInitThunk + 0x19
0x3f9d0: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full Version
