17258 Discussions
Memory requirement to compile different devices
Hi all,
Just to share that in case you encounter issue with Quartus II hang when compiling certain devices, you can cross check the following document to see if it might be due to insuffient memory for compilation:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/rn/rn_qts_dev_support.pdf
Great. I have been looking for this info. Thanks.
Thanks for sharing.
