16604 Discussions
Microsoft visual studio 2017 professional with HLS
NSuku1
Hi!
I see that the HLS compiler (Quartus Prime Pro 18.1) works with Microsoft Visual Studio IDE 2015 Professional. I would like to know if it works with Visual Studio 2017 Professional?
Kindly confirm.
Nivetha
AnandRaj_S_Intel
Hi Nivetha,
Few quarters ago i was trying to use Quartus 17 std with Visual Studio 2017 but i was facing lot of issue so i used Visual Studio 2010 as per documents.
Presently i am using Quartus 17, 18 both std & pro edition with Visual Studio 2010 for simple design, so far i have not faced any issue.
However the Intel HLS Compiler software does not support versions of Microsoft Visual Studio other than those specified for the edition of the software.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
MuhammadAr_U_Intel
Hi Nivetha,
As pointed out by @Anand​
Please refer to Intel HLS Getting Starter guide to see the version of Visual Studio/ GCC supported .
Un-fortunately Intel HLS Compiler software does not support versions of Microsoft Visual Studio other than those specified for the edition of the software.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls-getting-started.pdf
Arslan
NSuku1
Okay. Thanks for the clarification.
Nivetha
NSuku1
Hi all!
Can I use some other IDE other than Microsoft visual studio 2010 ?
Please let me know!
Nivetha
MuhammadAr_U_Intel
You can try using Eclipse following the guide.
https://www.intel.com/content/altera-www/global/en_us/index/documentation/xfy1510159781700.html
Arslan
NSuku1
Okay. Thank you.
Best,
Nivetha
NSuku1
Hi all!
I'm using Intel Quartus Prime software standard version. As per the specification given by Intel, I can use Microsoft Visual Studio 2010 Professional for HLS development. However, I could not download this older version of Microsoft Visual Studio as it is not available in the original website.
I hope there should be some alternative to this issue.
Nivetha
MuhammadAr_U_Intel
Did you tried the Eclipse ?
You can download Microsoft Visual Studio 2010 from link below.
https://visualstudio.microsoft.com/vs/older-downloads/
Arslan
