I have downloaded and installed ModelSim-Altera 6.1g (Quartus II 8.0sp1) Web Edition. The installation package is named as "80sp1_modelsim_ae_free.exe".
Then I downloaded license file from Altera's official site and created two Environment Variables LM_LICENSE_FILE and MGLS_LICENSE_FILE. I set their values to the license file path. The software product began to operate properly. By mistake I have deleted variable LM_LICENSE_FILE. Since that time the program fails to start with the following message: Error in startup script. invalid command name "?????????" while executing "LibraryGetMappings $new_ini" (procedure "InitializeINIFile" line 33) invoked from within "InitializeINIFile quitely" invoked from within "ncFyP12" (file "F:\Program Files\Alter@\80sp1\modelsim_ae\win32aloem/../tcl/vsim/vsim" line 1) I have created the deleted variable and reinstalled the product, but this did not solve the problem. See attachments for more details. Please, help me!Link Copied
Hi there,
Other people seem to have seen this. Read http://www.edaboard.com/ftopic87131.html One solution that seems to have had sucess is (See bottom of above linked page) 1) Uninstall modelsim 2) Run regedt32 (From Window Start Menu->Run) 3) In the Registry Editor window that pops up do EDIT> Find type Model Technology Incorporated and Delete that folder 4) Reinstall Modelsim Hope this helps- Mark as New
Thank you very much! Your instructions helped me to resolve my poblem.
Hi
I have a similar problem with my modelsim se 6.4c uner vista ulimate. before that i used to use it under xp and it was fine, i had to move to vista and now i can't run it under vista. it gives error in startup script invalid command name ".main_pane.mdi.interior.cs.vm while executing "GUIMAIN" invoked from within "ncFyP12" (file "c:\moeltech_6.4c\winn32/,,/tcl/vsim/vsim" line 1) please help thanks a lot- Mark as New
--- Quote Start --- Hi there, Other people seem to have seen this. Read http://www.edaboard.com/ftopic87131.html One solution that seems to have had sucess is (See bottom of above linked page) 1) Uninstall modelsim 2) Run regedt32 (From Window Start Menu->Run) 3) In the Registry Editor window that pops up do EDIT> Find type Model Technology Incorporated and Delete that folder 4) Reinstall Modelsim Hope this helps --- Quote End --- thank you this is very helpfull.i just resolve my problem
