17267 Discussions
ModelSim: Fatal: Trouble with Simulation Kernel
I try to use ModelSim-Altera Start Edition from shell on 64bit Debian/Linux. When I double click on a signal of my project, loaded under "work", it crashes with the following message:
$ export PATH=${PATH}:/opt/altera/13.1/modelsim_ase/linuxaloem/# ...# setting up project $ vsim Reading /opt/altera/13.1/modelsim_ase/tcl/vsim/pref.tcl ** Fatal: Trouble with Simulation Kernel.
I already tried opeining Modelsim from Quartus II, there it seems to work. Any idea why it crashes?
I am also observe the same issue.Can anyone have an idea how to resolve it ????
Thanks in advanced.
Mehul
I have found one possible cause of this type of error
Make sure all the undriven output signals in your verilog/systemverilog files assigned to zero value.
