16606 Discussions
ModelSim Wave Image Export Error - image file format "bmp" is unknown
NH_Dal
I am using Quartus Prime Lite 20.1.1 with ModelSim Intel Starter Edition 2020.1 Revision 2020.02.
No matter what image format I select, if I try to export an image from Wave, I get the error:
Is anyone else having issues exporting Wave images?
RichardTanSY_Intel
That's weird...I also get the same thing.
Let's me check with the engineering team on this.
For now, please use snipping tool or screenshot as a workaround.
Pietro4
Me and my mates have the same problem, I can't even print a readable file.
The only way is to print a pdf file but that's not what I need.
RichardTanSY_Intel
Hi Pietro4,
May I know what do you meant by "I can't even print a readable file."? Is the issue related to Modelsim? Could you help to describe more on this? Appreciate if you could share the screenshot.
Richard
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.
Pietro4
Hi ,
I managed to solve the problems regarding the printing of files.
I still have problem to export an image from wave, the same as @NH_Dal.
Thanks for the help.
Pietro
RichardTanSY_Intel
I am still pending for engineering to investigate on this.
It seems to work in Linux OS, could you try in Linux and verify whether the image export works?
Richard Tan
RichardTanSY_Intel
Hi @NH_Dal @Pietro4
This is a valid bug in Window OS and engineering will fix this in the future release.
As of now, the current workaround is to run the Modelsim/Questa Intel Edition simulator in Linux OS or you may use third party vendor tool to export the wave image.
If these is no further help needed, I will proceed to close this case.
Richard Tan
