16597 Discussions
[ModelSim] Where to see a log of the commands
Hi All,
Where can I see a log of all the commands, which ran in ModelSim ever by manual entering/typing in the Transcript window or by using ModelSim buttons?
Thank you!
--- Quote Start ---
Hi All,
Where can I see a log of all the commands, which ran in ModelSim ever by manual entering/typing in the Transcript window or by using ModelSim bottoms?
Thank you!
--- Quote End ---
Apologies dmitryl but I didn't know Modelsim has bottoms?
I meant "buttons" :-) So, do you have an answer? Where is a log file of ModelSim/Questa located? What's the log name?
--- Quote Start ---
--- Quote End ---
yes the filename is "transcript" and should be either in modelsim directory or as decided by modelsim.ini
for example you may have the following ini command:
; File for saving command transcript
TranscriptFile = transcript
How can I change a location of the Transcript File?
Currently it's located and updated here: "C:\questasim64_10.4c\examples\transcript
But, the project itself is located here: "D:/units/hp/led/msim/project"
So how to set so all the Modelsim files will be located/updated in the project directory?
Is there any response? Should the transcript file be in the project directory? How to change its location?
